Terc.......
YOU explain it to my wife when she asks.![]()
LOL I feel your pain!!
Terc.......
I guess I'm lucky, my girlfriend tends to just ignore my tech budget... I just tell her it's for work.![]()
Ah, point taken.![]()
By the way, grats on your stable overclock Evoic. Just noticed it in the Official OC Database thread.
Currently stress testing my E6420 @ 3.6ghz. Have let Asus handle the voltage up till now.
Temps at 50deg with watercooling.
Woot!
Back on the throne for fastest E6420 stable overclock!
I'm just getting warmed up!! Get ready for some competition up therre
I've got a 6600 and 6420 I keep swapping back and forth. Both are stable now to mid 3.6's. Pushing higher and swapping to another motherboard....I'm coming!![]()
Here is what I'm playing with now...both the 6600 and 6420 can do this.
You're Orthos stable at those speeds?!
What is the week/processor code of your E6420!?
I'm just happy I've taken back the top for now. Not sure if I'd be willing to go much higher, although I still need to make an official fastest unstable, so far I think I was around 3860Mhz...
No. not yet. The E6420 is a L709, the 6600 is a L701. I can boot over 3.8Ghz tho.
A whole 5 MHz!
I'm sure your board had an option that would boot 3651, you shoulda used it and saved your chip the volts.![]()
I'd go higher, but I don't know if I could live with the thoughts of someone killing their chip just to best me by 5 MHz.![]()
Speaking of lower temps...
I just found this, and thought I'd send people to check it out if they hadn't already heard about Masscool Shin-Etsu x23 thermal paste.
http://forumz.tomshardware.com/hardware/DaClan-Review-Thermal-Interface-Shootout-ftopict221751.html
If the review sold you on it, I found a place to buy it:
http://www.crazypc.com/products/x23-778d-50119.html
http://www.ajigo-store.com/se7783d.html lower price, but I've personally never shopped here
:EDIT:
sorry guys, those links are for the 7783D revision of the thermal paste. The guy that organized the test says that it is a slightly better revision, however, they used 7762 in the tests.
It can be found here: http://www.crazypc.com/products/50118.html
And while I'm at it, the best instructions I've found for applying a super thin layer of paste:
http://amdforums.com/showthread.php?s=&threadid=230649&highlight=Application
Lookie what I found.![]()
http://forums.pcper.com/showthread.php?t=415964
I checked around and this guy is a great seller on that forum and his reputation is extremely solid.
Shin-etsu for $8 shipped !
Can't beat that anywhere......![]()
I promised that I'd send some busienss his way for being so helpful to me while I was hitting him up with questions.
If you buy a tube of this stuff - tell him Evo sent you.
Please.
Thanks!
p.s. He only has about 30 tubes left ! !
Uh oh, what's the wife gonna say?
She's gonna' say nice job on the 40% savings for your stupid computer toys!![]()
How is this thread 12 pages long and there's only like 7 of us on the e6420 section in the core2duo overclock database?
Does anyone know if the e6420 has a FSB wall? My computer is currently rock solid at 485, but I can't even post at 486...which doesn't seem to make any sense.
e6420
P5k Deluxe
Ultra 120 Ex
485 x 7 = 3.395
CPUv 1.475
everything else auto
I'm also rock solit at 450 x 8 = 3.6, so I know it isn't the CPU. Could it be the FSB, or do I need to worry about the NB or RAM?
Has anyone topped 485?
-Graham
e6420
P5k Deluxe
Ultra 120 Ex
485 x 7 = 3.395
CPUv 1.475
-Graham
Wow, over 3 days of downtime for the forums and it's still really slow...
Anyhow, I will be starting a list of everyone's fastest stable overclock (4 hours orthos please) on their E6420 in the first post on this thread. I will need your speed, voltage, processor code, motherboard and bios version. I will try to keep this as up to date as possible. Please post your current best following this post.
Also, I would like to put together a guide of what, if anything people find helps outside of the Conroe overclock guide.
I would make a vote that in addition to a visible window containing the 4+ hour Orthos/Dual Prime shot, that a 3dMark06 run with output visible be included to prevent people from posting systems that aren't truly stable. You might be CPU stable at 3.5, but loading up 3dMark shows you otherwise.![]()
I've never seen a system that was 4hour+ stable on Orthos, that couldn't take a run through 3dMark.
QFT, LF Phase OCer on this badazz cpu.I'm pretty sure it's cooling that's holding it back.
I'm baaaaaackk....just posted this up in the Intel OC thread.
I'm taking back the E6420 crown...for now...moving to a D-Tek Fusion this week, went from P5B Deluxe to DS3 to push higher.
User Name: dnottis
Stability: 6 Hours Orthos
CPU: E6420
OC: 3680 Mhz
Stepping: 6 B2
Week: L709
Code: A171
Vcore: 1.550 (BIOS), 1.49v actual
Cooling: Water
Cooler brand/model: Thermochill PA120.2, Swiftech Apogee, D5 Pump, MCW60, 2x 75CFM 120s @ 12v
Motherboard: Gigabyte DS3 rev.1, C1 chipset
Bios Version: F11 Bios
Operating System: Vista x64, XP SP2
RAM brand: OCZ 2GB
RAM rated speed: 8500
RAM actual speed: 920Mhz
Latency: 5-5-5-15
Very nice overclock!
Now SOMEONE hit 3.7 already!
