buy.com just rolled out a L649G592 to me.
I should have my dtek fuzion and mcr 220 early next week.
I got a L649G590, walls at 456, OCd to 3.2 easy, over that needed 1.5 to even post. Managed 3570 @ 1.55v. Not impressed.
I got a L649G590, walls at 460, OCd to 3.2 easy, over that needed 1.5 to even post. Managed 3570 @ 1.55v. Not impressed.
These may be pretty hit or miss, I'm at 3504Mhz 8 hour orthos stable on just 1.425v (1.41v actual)
I've made it into windows at 3.8Ghz, but it took 1.56vcore.
I cant even boot over 456, wall is at 456.![]()
I have the same week code,
managed to get stable single 32M superpi @ 3500Mhz
but orthos only stable @ 3.2Ghz
F8[F8];1030980654 said:I haven't fully pushed mine yet, I have a L646G527, running at 400x7. I highly recommend this cpu, buy it instead of the 6600, and spend the money you would save on a better cooler.
That's the truth if I've ever seen it.![]()
I freakin love this chip. I'm getting 3.4ghz w/ 1.45v (I should probably even bring that down a little bit). Solid as a rock.
Hitting 3.5+ with less than 1.4v is what most people are looking for.![]()
Thats not really all that great. My 6300 is rock stable at 3530 @ 1.35v, 3570 @ 1.37 and 3590 @ 1.39. My 6420 which I dont even to consider to be a good overclocker can run 3520 @ 1.525v. Hitting 3.5+ with less than 1.4v is what most people are looking for.![]()
Well, I just started doing some serious overclocking on my e6420 and I got it to 3.6GHz on 1.4V no sweat. Thats with a 450FSB.
I have a feeling I could top out about around 4GHz at 1.5+ volts because it does 3.2GHz at stock, but I don't want to until I get the room temp cooler. I may get the commando itch again soon though.
I took a screen shot but it is worthless because it only shows a super PI of 14 sec (sweet) but my CPUz speed says 2700MHz due to the fact that I still have power management turned on
Also, I didn't ask my wife yet if she minds me posting a hot picture of her one the web because she is on my desktop![]()
Screenshot!!!
Don't let this smart 'A$$' spoil your fun. You've got a good chip dude.![]()
[F8];1031007081 said:I don't know if all programs report voltage properly, but I'm happy to report I'm at 3.2ghz on stock voltage.
My puter got upgraded, so I am gonna post my new OC result.![]()
User Name: BigDaddy85
Stability: 11hrs 30min (No Error) Orthos - small FFTs
CPU: E6420
OC: 3,520 MHz
Stepping: 6 B2
Week: L646
Code: G527
Vcore: 1.51v
Cooling: Air
Cooler brand/model: Zalman CNPS9500 LED
Motherboard: eVGA 680i (122-CK-NF68-TR)
Bios Version: P27
OS: XP 32-bit
RAM brand: G.Skill
RAM rated speed: PC2-6400
RAM actual speed: 800
Latency: 4-4-3-5
Validate - http://valid.x86-secret.com/show_oc?id=193001
4 Fun 3.733 Ghz - http://valid.x86-secret.com/show_oc?id=193253
SS of 11 hrs and 30 min stable - http://www.ritkf.com/Pics/11hr30minstable.JPG
1.55, and it crashed within 5 min of OCCT lol... I could push more voltage, but i dont wanna to get more heat in though.What voltage did you need to get 3.733Ghz?
No change to NB, SB, or FSB voltage on my system. I only increase my FSB to 440 and increase my cpu voltage, too. That pretty much what I did to my current computer.My question is, what voltages are you guys using for NB, SB, FSB voltages?
Oh hell, should i?
Edit: I tried to OC back to 3.733 GHz @ 1.59 volt and it crashed 1 min of OCCT....
O hell I am happy with my cpu anyways.
well my chip runs great in winxp... loaded in vista and for some reason its not liking the oc anymore.. I will play with the volts and ram speeds. What do you think is good volts for the ram in my sig. I really dont want to go higher then 2.2 or 2.25v. Just wondering....
just for shits and giggles...
This is the fastest I can get my 6420 to run. Ofcourse it isnt orthos stable tho.
[Images removed for the sake of saving space]
