cyberslag5k
- Jun 29, 2004
I have a new E6400 Core 2 Duo proc running at the stock 2.13GHz. I think I may have scratched the contact surface of the stock cooler while I was removing the older contact solution (it said to use a plastic tool, it appears the side of a credit card is too hard, eh?). I'm using arctic silver 5, I put a thin line on the center of the plate as per instructed.
Anyway it idles at about 45-50 degrees Celsius on one core and about 40-45 on the other. Doing a stress test, I let it get up to 80 before I stopped the test. This was letting it run for maybe 2 minutes (I used BurnInTest v5.2 and monitored it with SpeedFan). These temps seem high. Are they, and if so is my little blunder with the HSF to blame? Or perhaps is it not seated properly or something?
