e6400 on P35-DQ6
No help on the overclocking board so I came over here:
I'm wanting to get closer to a 500fsb but I'm having trouble getting over 400 stable. I know 400 stable isn't anything to be depressed over but I would like to see it get a little higher.
Currently:
e6400: 3.2 @1.45v (Don't want to go higher than this because I'm on air [This was purchased around Aug 06])
FSB: 400 @ +.1v
PCI: 100 @ +.1v (Not sure if I need this just upped it .1 for the hell of it)
MCH Overvolt @ +.1v
Team Elite 667 3-3-3-8: 800 @ 2.15v (Very loose timings for the time being)
Temps: 45c idle, 52c load on a Zalman 9500 (This could be limiting? But the temps aren't that bad)
All told prime/orthos stable @ 8hours (Wanted to mess around and lower voltages before I go all night) But after an hour or so of BF2 pc locks up. Dropped do to 380 and no problems. But it did run orthos stable for 8 hours so...
Thats pretty much it, regardless of how I change the multiplier or what voltages I put on FSB (I've gone up +.2v still no change) it hangs on Windows loading (It boots @420 w/x7 multi). The ram will go up to 550 @ stock voltages (Tested) so I'm not sure where the limiting factor here lies. I'm assuming that my e6400 just doesn't want to go over a 400mhz FSB. But I've fed it and been good to it....
It seems like there is a hole somewhere between 2.9ghz and 3.2. At 2.9 I can run default vcore but 3.2 it goes all the way to 1.45 or it will throttle. That a little odd? Someone suggested I lap it but what will that really do for me besides make (Hopefully) it run a little cooler? Its still going to need the high vcore to be stable right?
Also, I know 1:1 gives the best performance but if the ram will run 1200 should I change divider and let it run 1200?
Thats all I can think of to add, any suggestions would be much appreciated.
You're running very aggressive timings for your RAM (or any RAM for that matter).
For DDR2, the 667Mhz bandwidth runs on a 333Mhz FSB.
memtest86 the ram as you raise the FSB. You should run 5 5 5 15 or 5 5 5 18 5 5 5 16 is not right.
Its probally the ram. You already have a signifcant OC on it so there is probally not a lot of headroom left.
I was just guessing at the timings cause I was to lazy to look, its running 4-4-4-12 right now. The ram will run at 550 (Tested in memtest for over an hour no errors). I think its like you said, I'm out of room with air. But thats OK :p I'm happy with it, I'll go ahead and lap the HS though see if I get anything more out of it.
