When I booted up my system for the first time I heard clicking noises. I looked inside the case and noticed the CPU fan wasn't spinning. I promptly turned off the computer and turned it on again soon after to have a closer look. This time I didn't hear any out of place noises, but I observed that the CPU fan made a small rotation the moment I turned the computer on. I didn't leave it on for longer than 10 seconds and didn't try turning it on again as I don't want to fry the CPU. There was no warning about the fan displayed on the screen (just the white boot screen followed by DOS).
The fan is plugged into the motherboard, there is nothing blocking the blades.
The system consists of the following items (all straight out of the retail box):
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor
http://www.newegg.com/Product/Product.asp?item=N82E16819115004
GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813128012
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.asp?item=N82E16820231098
XFX PVT71PUQF3 GeForce 7900GS 256MB GDDR3 PCI Express x16 Video Card
http://www.newegg.com/Product/Product.asp?item=N82E16814150208
Seagate Barracuda 7200.10 320GB Hard Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
Antec Neo HE 550w Power Supply
http://www.frys.com/product/4653878
What are the possible causes of this and how can I track the problem down?
Thanks in advance.
edit: I may have found my answer: http://www.hardforum.com/showthread.php?t=1109483&highlight=fan
I should search BEFORE posting next time.
Thanks in advance.
