Hey all, I have a few questions and would like opinions as well.
I was just messing around with BIOS settings and looking at OC/Temps.
Right now at 3.0Ghz
vcpu: 1.35
vdimm: 2.0
2.8Ghz:
http://i2.photobucket.com/albums/y5/DJS3/2.jpg
3.0Ghz:
http://i2.photobucket.com/albums/y5/DJS3/3.jpg
Memory (CPU at 3.0):
http://i2.photobucket.com/albums/y5/DJS3/3-1.jpg
How does everything look? if anything stands out at you that I need to change something please let me know. I can give more info as well.
When I run orthos and cpu is at 100%, is this considered load? Im asking this because when I use TAT's 100% load I get a good 5c higher than when I use orthos. Which one should I trust?
At 3.0Ghz Im getting 43/46 idle and 48/52 load using Orthos. I dont want my temps to go over 55 really. Im pretty baffled that I dont have Idle temps of 30c with my WC setup, i dont know if its my WB or what... Ive done the AS5 perfectly and reseated the DD TDX WB quite a few times. Flow seems to be good as well.
Anyways, what do you guys think? Good/Bad for my first OC? Anything I should change or strive for?
Thanks!
Right now at 3.0Ghz
vcpu: 1.35
vdimm: 2.0
2.8Ghz:
3.0Ghz:
Thanks!
