So I'm from the good ole' days of unlocked 2500+ Barton overclocking pushing it to the limits and have gone back and forth between wanting to OC my C2D in my new system but for a while decided against it as I didn't really need the power at the time. I mainly run Visual Studio 2008 pro, Adobe CS, and Winamp with the occasional COD games. However I have decided I want to OC it and squeeze some extra performance out of it. Heres the specs.
E6300 Conroe
ASUS P5N-E32 SLI
2gig (2x1gb) Geil DDR2 800 @ 5-5-5-15
Cooler Master Silent HSF
Cooler Master 650watt PSU
Once not too long ago I OC'ed it by setting the FSB to 1600 and putting it in synced mode (What exactly is the "state" of synced mode anyway?) according to the recomendations of some people. It booted and CPUZ registered 2.8ghz at 1600FSB and the memory at 400mhz as it should be. It ran stably in OrthosII for almost 4 hours but after gaming for a couple hours it would freeze or crash (hard restart) so I downclocked it back to stock.
Today thinking it's because I never changed the Vcore (I left it on auto back then) I put it back on the OCed settings with Vcore still auto and rebooted and CPUZ showed the Vcore to be 1.58......Thats insanely high so I went back to the Bios and set to stock speed but manually set the Vcore to 1.35 (It always showed ~1.42 on default settings and auto voltage) abd checked CPUZ. Sure enough with a manually set 1.35 Vcore CPUZ was registering a ~1.42 Vcore which makes me think I can't trust it and that the 1.58 I saw earlier isn't correct?????
My other problem is this: I know in a real world situation 1:1 ratio is better then 3:2 due to throughput and bottle-necking issues when you take them out of balance. However when I set it to Linked with a ratio of 1 to 1 and a Bus of 800 (thus Mem mhz 800) it wont boot. This doesn't make sense, the Bus is at 800 (processor is built for 1066) and the mem is 800 which is it's rated speed and it wont even make it to post. I instead tried 3:2 with a modest 1200 FSB giving a 300 bus speed and 400 mem speed and it boots fine to 2.1ghz. This is a mild overclock over the 266.7 Bus, 1066 FSB, and 400 mem but I would really like to have it in 1:1 and reach ~2.5+. Any advice?
Edit: Update- I put it back in Synced mode, 1600 FSB (Bus speed showing as 400) and it's at 2.8ghz. I did however set the Vcore to 1.4 manually and it booted and ran fine in CODWaW just now . So it boots fine at 1.4 where as with auto Vcore it would show up hitting 1.6.
Also, what is the diff between Synced and 1:1 because right now it's on synced but showing up as 1:1 in CPUZ.
E6300 Conroe
ASUS P5N-E32 SLI
