e6300 having issues going over 2.8ghz
I'm a little new to this so please be kind.
my setup is:
e6300 running at 400x7 @ 1.3-1.4v -- doesn't matter
vigor monsoon ii
corsair 6400c4d 800mhz 4-4-4-4-12 @ 2.1v
evga 680i
I've tested this setup with orthos running for 6 hrs without returning any errors so I think I'm stable at this setting. However, at full load Speedfan is only showing a temp of 45-47c on my cpu which should still be within optimal range. now given that if i raise my fsb any higher or loosen my timings and raise my memory speed i can't even boot up windows. What could be the issue? Could someone help me please?
Thanks in advance! :)
Newer bios available?
What happens if you just bump it to 450 or something like that? Possible FSB hole on yoru board over 400mhz.
I have the latest available bios.
What do you mean an FSB hole? I can raise my fsb to 450. It just won't load into windows.
Sometimes boards have a "hole" where it won't boot. But if you get past that, it will start booting again.
Well I dunno exactly what did it but I disabled a lot of bios features and changed my fsb to 425x. The memory is running at 850mhz 5-5-5-15. Been running orthos for about an hour and it seems fine thus far!
Any advice as to what I can do next go further?
If you're serious about testing for instabilities then use 2 sessions of Prime95 instead. Orthos has a tendency to be too nice to your cpu.
How so? As far as I can tell, it does the same tests on two cores that would be done if you were using two instances of Prime. Orthos pegs both CPU's at 100% and has a variety of tests (blend, large FFT's, small FFT's) just like Prime95.
Because numerous people have found themselves orthos stable, and not prime95 stable. Myself included.
System passed 3dmark01 (forced software mode) + winamp (looped) + orthos for 24 hours straight. I start playing Fear and odd things start to happen. So I did the following:
3dmark01 (forced software mode) + winamp (looped) + 2xPrime95 (small FPU, blend) and within 6 hours got error for 1 core.
So no, I dont trust Orthos.
I have both so maybe I'll see if I run into problems with Prime95 vs. Orthos.
