AliceCooper
- Mar 25, 2007
So besides the FSB being like 266mhz less on the E4300 than tha E6300 whats the difference do they still OC well and does that FSB really matter?
The difference between a 9x multi and 10x isn't going to make much difference. With the E4300 and E4400 you're going to hit the top of the CPU's abilities before you'll max out the FSB. If going for the max overclocking value, stick with the 4300.
there hasn't been much said about the e4320. more cache is always good, but the price and how it compares to the current e4xxx processors will determine if its worth it.Guys what about the 4320? Is that going to be worth it? (For the extra cache)
an e4300 can be clocked similar to an e6300, but do not be mistaken they are not the same chip. the e6300 is a conroe, has virtualization support, etc. now if that warrants a purchase over an e4300, that's up to you. it's just important to state that they are not the same chip.the e4300 and the 6300 are the same chip
one is clocked for 800mhz fsb and the other is for 1066mhz
you can actually run the e4300 at 7 with a 266fsb and its the same as the 6300 !
e4300 can hit 3,3ghz or 3.4 very easily and only using about 1.40volts
which is nothing get a after market cooler and your temps will be like stock
these chips don;t get that hot wit i run my e4300 at 3.3ghz on a DFI 965p-s
and its very fast you can hit this speed with cheap 667 ram for christ sakes
