TheInternet1980
- Sep 23, 2005
What in God's name happened here? lol
Reason for trading my poor overclocking quad for a dual
1. I wanted to.
l
I think you've rather much shown how stupid you are by linking that and not even realizing its a photorealistic render. Look down the page champ. You aren't going to "straighten" anything out. You're a pompous what, 18 year old "consultant". Meaning you what, build computers for people in your spare time? Come now.
I'm a RN kid, what have you got, an A+ ?![]()
Whole article - http://www.legionhardware.com/document.php?id=737
Quad is better for gaming, need 4.2Ghz dual to match it at lower clocks.The whole review shows more of the same. I went back to my Q6600.
Where was the Q66 in that review?
5.2?
If anyone cares...I'm trying to prime @ 4.2, and having a rough go at it.
Seems to want me to POUR on the volts now for any kind of stability over 4ghz.
I tried to prime @ 1.326, but the temps made me nervous. (77-78C, with Coretemp offset -10 degrees to correct TJMax.). Once I replace this shoddy ninja with a Xigamtek 1283, I may be able to prime there with stability, and see where else I can get to.
was tweaking a bit tonight, and am looking prime stable at the following
Memory is 1:1, 5-5-5-15-54
Unfortunately, my board's NB HS height will not allow me to orient the HSF (xigmatek HDT-1283) so that air is exhausted out of the back of the case.
I'll be replacing that NB HS with this...
http://www.xoxide.com/noctua-nc-u6-chipset-cooler.html?productid=noctua-nc-u6-chipset-cooler
Then turning the cooler to blow out the back of the case instead of @ the powersupply. Should net at least a few degrees C cooler @ these settings.
Case I have is this...
http://www.xsreviews.co.uk/reviews/cases/lancool-metal-boned-k7/
so the old e3110 will do 4.2 huh? nice.i have the q6600 at 3.42, still hopin for 3.6 if i can get pwm and nb temps down.
