E2160, what temps should I expect and accept?
WMBlalock
Alright, well I got my Gigabyte GA-P35-DS3L board and Pentium E2160 (1.8ghz stock) running perfectly stable at 3ghz (9x333). Supposedly these things can run way faster, but I just want something that will be fast and reliable for 24/7 use over the coming years. What temperatures should I be considering for 24/7 use and longevity? Right now it idles at about 30C and after running SP2004 for 29hours the max temperature it reached was 60C and the average temp during the stress test was 57C. This is with the Arctic Cooler Freezer 7 Pro. Are these perfectly acceptable temperatures that I shouldn't worry about? What is the max temp I should run this things up to on a daily basis and at what temp should I worry that it's running too hot? Thanks guys!
- Mike
That seems a bit high for a Freezer 7 Pro. I've heard that that cooler was an excellent yet affordable cooler. I have my E2180 running at 3.24Ghz (tops out at 3.5Ghz) with a Zalman CNPS9500 and I let Prime95 (IIRC) run until temps stabilized. I can't remember the exact figure but I remember it was nothing to get worried about.
I'm guessing that SP2004 has the ability to torture your cpu? If so, keep in mind that normal apps (Crysis, Bioshock, whatever) aren't going to bring your cpu anywhere near that temp. It's interesting that you let it run for 29 hours. I usually run my suite of torture apps for 20-30 minutes each and then get too bored or impatient to let then run any longer. It works for me.
I had that same Gigabyte board for my E2180 and it was completely useless for overclocking. As soon as I swapped in an Abit IP35-E, I was able to hit 3.5Ghz. Mine was a version 1.0. Is yours a version 2.0?
Yeah, mine is version 2.0. I had a busy weekend so I wasn't by the computer much, thats why I left it for 29 hours.. not a bad idea though! At stock speed 1.8ghz the freezer 7 pro was keeping the cpu at 22C idle and 35C under full stress, it was keeping the thing ice cold. The temps went up quite a bit when I went to 3Ghz, but that is fine.. I just wonder if they are within reliable standards or if I should tone it down to save the life of my processor.
- Mike
They're within reliable standards. If you check my sig, I also have an AC7 Pro with an E6400 OC'd at 3.2Ghz. Idle temps are 42C, 56C at load. Ambient temp is somewhat since it's kind of cold at the moment in California. During the summer, idle temps were 48C and load temps were 60C.
But anyway, no worries about your temps. What's your ambient temperature? What is the Vcore set at?
My ambient temp was kind of warm when i took those temp readings, but it goes up and down since I live here in FL but i usually keep it around 75F i would guess. Everest reads 1.36-1.38 for the core voltage.. In the bios i have it set to auto so that it can automatically add and take voltage as needed.. is that the way to go?
- Mike
- Mike
IMO, no. Some motherboards will provide too much voltage while others will provide too little voltage. By adjusting the voltage manually, you'll know can lower the chances of the motherboard providing too much voltage, which raises temperatures.
So adjust the voltage yourself. Start from your stock voltage (1.325 IIRC), then slowly move up till you find the voltage where your OC is stable. YMMV but I managed to hit 3.2Ghz with at 1.328 after vdroop (1.35 I think in BIOS).
At those temperatures, I wouldn't really worry too much about it. Aslong as you keep it under 85C or 100C, I can't recall which was the limit of these things. You really should control the voltages yourself as motherboards tend to give it too much voltage which would increase your temperatures for no reason. My E2180 at 3.2GHz would peak at 55C under Prime95 for roughly 10 hours at 1.405v I believe.
Yeah, I am working on controlling it myself, but am having a very hard time finding out exactly what voltage my cpu is getting because 3 things give me 3 totally different numbers, for example
When I manually set my bios to 1.37500v and reboot, the PC Health Monitor in my bios shows the voltage as being 1.348 and then when I boot into windows Everest tells me my cpu voltage is 1.31! It is like that throughout all cpu core voltage settings in the bios, i get 3 different numbers.. do you think I could have a motherboard problem? Also check out my other thread in the Motherboard section on my memory voltage. I have 1.8v memory, if i set the bios to auto it puts my mem at 2.00v and if i manually select my voltages and set the memory to "normal" it gives me a mem voltage of 1.872v and there is no undervolt options showing up in my bios so the lowest i can get my 1.8v memory too is 1.872v no matter what i try! Very annoying! I wonder if i have defective voltage regulators on my mb?? What do you guys think?
- Mike
All recent Intel motherboards have voltage droop which shows lower voltages in Windows and such than what you set in the BIOS. As long as its less than a 0.1v difference, I wouldn't really pay attention to it. Although, if you would like, try updating the BIOS to a newer version but make a backup of your current one first just in case. Gigabyte may have added lower memory voltages and made the vdroop a tad smaller.
As a starting point, at 3GHz my E2180 only needed one notch of vcore to be rock stable (1.3450v). You may be able to get away with that little voltage but its really up to you to find the most stable configuration. Hope this helps.
I know the boards have Vdroop, but what i am confused of is which number i should trust the most.. the bios's reported voltage, the bios's set voltage, or everest's reported voltage.. like you say you use 1.3450v, what reading are you taking that number from?
- Mike
- Mike
Well I use the set voltage and the voltage reported by CPU-Z for my overclocking. If you check back to my last post, CPU-Z reported 1.328 while the set voltage was 1.35. I reported 1.328 as my actual voltage after vdroop
neg, where are you?
sorry, neg has a 2160 with a noctua NH12P and which is OC'd to 2.6 on a P35 DS3, and i think he gets like 25...
i will email him...
Hai There! as soundguy says, i have an E2160 OC'd to 2.6 on my P35-DS3. its upped one voltage notch in the BIOS (two after the CTRL-F1 trick).
Idles around 27degC and under Orthos never goes a degree over 56. Your temperatures are FINE, the TJunc for these cpus is 100deg anyways.
Im using a Noctua NH-U12P being controlled by the SmartGuardian, never goes over 900rpm :)
--neg
