DX79TO benchmark test
ksingh707
I have an intel DX79TO motherboard and im trying to run the benchmark test on it. If anyone knows how to run the benchmark test on this and where i can download the benchmark test software or program, id appreciate it.
kirbyrj
Which benchmark test are you talking about? "The benchmark test" doesn't tell us anything.
I would probably start with CPU-Z though to get an idea and good information about your setup.
ksingh707
im trying to run a pc check on the board. Every time i try and load it up it says (Cannot find file EURODOS.INI.)
pendragon1
how are you trying to run this "pc check", in os or bios? maybe post a pic of what your seeing(drap n drop into message box).
ksingh707
ksingh707
the bios are not updated they are from 2012, can you recommend where i can download the latest bios? and do you think that will help?
pendragon1
that link is to the newest bios. it might. it its loading from within the board/bios, hopefully it will rewrite whatever is missing. otherwise, idk what else it would be. like i said though, i dont see a test selection on your last pic, is it in the boot menu? i dont see what your selecting to get that first pic.
ksingh707
thank you I appreciate it
