Apr 3, 2006 #1 U u8myrice 2[H]4U Joined Dec 6, 2005 Messages 2,155 My 42" HDTV Sony has a DVI port, so I wanna use DVI-to-DVI on my FX5500. Does anyone know the best place/prices to buy this at? Thanks.
Apr 3, 2006 #2 F FraGGleR Limp Gawd Joined Oct 4, 2004 Messages 384 monoprice.com dirt cheap, good quality.
Apr 3, 2006 #3 D darktiger [H]ard|DCer of the Month - April 2007 Joined Apr 10, 2003 Messages 11,819 I usually use http://www.smarthome.com/ Really like them..
Apr 3, 2006 #4 D Dew 2[H]4U Joined Jun 23, 2003 Messages 3,854 FraGGleR said: monoprice.com dirt cheap, good quality. Click to expand... Seconded.
Apr 3, 2006 #5 I IDversusEGO Supreme [H]ardness Joined Oct 30, 2003 Messages 5,015 FraGGleR said: monoprice.com dirt cheap, good quality. Click to expand... thirded? I like em too.
Apr 3, 2006 #6 U u8myrice 2[H]4U Joined Dec 6, 2005 Messages 2,155 Is there a huge difference between "High Quality" cables and "normal" cables? The high quality is doubled the price of the normal ones.
Apr 4, 2006 #7 I IDversusEGO Supreme [H]ardness Joined Oct 30, 2003 Messages 5,015 thicker jacket, better connectors. they just tend to hold up better over time.
Apr 4, 2006 #8 J jebo_4jc [H]ard|DCer of the Month - April 2011 Joined Apr 8, 2005 Messages 14,566 Generally, I don't think the quality of DVI cables make much difference in terms of PQ, but like has been said, they might hold up better over time. FYI, if you are a Sam's member they have good quality Phillips DVI cables for about $12 iirc
