Somebody has to have some good info for me.
Here's something that I was asked and am not sure exactly how to answer.
My answer at this point, is that Most people aren't going to notice any major differences.
There is a difference, but can you or I tell? not really without looking very hard.
Now, for the question...
Is using DVI going to gain visual quality that is noticable? gaming, surfing, dvd...
additional part: A friend said that in moving to PCI-Express graphics cards from AGP, you will notice
more of a difference between the two types of connections (DVI and dsub).
Same question. Is DVI noticably better than the normal dsub connector?
question I really want answered: you could probably ignore the previous stuff.
example of usage
I buy an LCD, and it has a Dsub connector and DVI connector. Using a PCI-Express video card.
Am I going to notice a huge difference in the visual quality?
Resources for information is appreciated. maybe visual evidence for either as well.
example of usage
