dvd/cd & virtual drives disappeared under 'my computer' - help!
Visec
I just bought a new self-built computer and the past 3 months it's had zero problems, I consider my knowledge on computers to be advanced/expert and this problem is peculiar. Under window "My Computer" the DVD/CD drives aren't showing up nor are my Virtual alcohol 120% drives. Other drives such as floppy, and my three hard drives show perfectly however. I installed Crysis a month ago and the DVD player worked perfectly.
The fact that the Virtual Alcohol 120 drives vanished and stopped working at exactly the same time as the DVD/CD players stopped working leads me to believe it's an OS or software issue, not a connection issue, Im using Vista 64.
Device Manager has a ! sign under both cd/dvd saying "driver may be corrupt or missing". But upon downloading the official drivers from manufacturers websites I get an error saying: Windows encountered a problem when trying to install the drivers"
I reinstalled Alcohol 52% and 120% and they install fine but drives don't show up under 'my computer' and executing .mds files nothing happens. This leads me to believe it's not a jumper issue or connection issue but something else within the OS.
Usually I have easy times identifying computer related errors but this problem eludes me.
I'd try a system restore, a similiar thing happened to me, and that helped, hope you havent turned it off.
How about uninstalling them in the device manager, and let Windows reinstall after a reboot.
ok ill try.. that still wouldn't explain why alchohol 120 virtual drives fail to show
I thought you guys were [H]ard:confused: bump! bump! bump!
But seriously, missing cd dvd and virtual drives.
I havn't updated my IP35 motherboard (I don't have a 3.5 floppy which is required) could that be an issue?
Could it be due to not installing vista service pack 1 yet?
