maximus01701
- Apr 25, 2008
Ok, so I just got done with one of my builds
and I am having a few problems here and there...
Ok so for starters my system specs
Ga-Ma69GM-s2H
Corsair vx550W
AMD 6000+
EVGA 8800 GT
2 gigs ram
4 Sata Hard drives
1 Sata DVD drive
Rosewill RC-209-ex Raid controller card.
Ok... So I have been running the system with just two IDE hard drives and all was running great.
Until I got 4 new Sata hard drives that I put into Raid 0.
To do this I used the 4 SATA ports on the mobo and then got a PCI Rosewill Rc-209-ex Raid controller card to use for my DVD drive and ESATA ports...
After plugging everything in (except for the IDE hard drives), I was unable to boot from my DVD drive running off the PCI card. So I didn't feel like messing with it and plugged in my old IDE drive I had from another system. After doing so everything went great. I then got around to installing windows on the new set up and everything went great. But after it was up and running. I was able to see the Sata DVD drive but was un able to read ANY CDs off of it. I then proceeded to plug in my old IDE hard drives to get some old files off. And when ever I do so, my computer hangs like CRAZY.
First it kinda hangs on Detecting IDE drives then it hangs on loading windows (takes about 20 min for it to start up). And after it loads, it doesn't even see the drive in windows.....
So to make a long story short...
I have 4 sata hard drives and 1 sata DVD drive.
The hard drives are running off raid 0 from the mobo and the DVD drive off the PCI card I got.
After setting everything up, windows recognizes the DVD drive but is unable to communicate.
ALSO when ever I plug in an IDE hard drive, boot times soars to about 20 min and is still
not recognized in windows.
I think I kinda covered all bases, thanks
-Cheers
Ga-Ma69GM-s2H
Corsair vx550W
AMD 6000+
EVGA 8800 GT
2 gigs ram
4 Sata Hard drives
1 Sata DVD drive
-Cheers
