Just wondering what are peoples feelings on dust filters? It seems the pro dust filter crowd has had a resurgence lately.
I've only ever used dust filters a handful of times and each time I stopped using them because the annoyance and disadvantages of them outweigh the "good" of using them. Really they don't stop dust from getting in your case, all the filters do is slow down dust buildup somewhat. Mileage may vary I guess if you don't vacuum much, house cleanliness or own a pet. Vacuum around your PC once a week? No? Me either Filters also do nothing to prevent that fine, tiny dust from getting in the case. Filters and even grills greatly decrease airflow, add noise and turbulence and dust still gets in your case and on your parts. Dust even gets in the case from circular airflow around intake fans.
I find much less dust issues in high airflow, no filter cases and open air test benches that sit out for months or even years. You don't see dust filters on consoles either.
I've had high end PC parts caked in dust and they still work fine. Opps, oh well blow it out..
What I've been doing for years is every 2-6 months or whatever take the case outside and blow it out with the compressor or canned air. With consoles or similar electronics with fan intakes that you can't open same thing once every few years using canned air works good enough there as well.
I just took apart and blew dust out of my old Dreamcast for the first time last week. There was hardly any dust in there anyway and it was used alot. All the game consoles have intake fans these days but they are so low flow I'm betting there won't be much dust in them anyway even after years. Unless you have it close to the floor or carpet maybe.
The best PC filters I used are the Lian Li ones that look like a large sponge with high airflow. The typical screen types are all basically the same.
hmm, just ran out of beer..
