DeathPrincess
- May 15, 2010
I just noticed that GOG now has dungeon keeper 1 and 2 listed (I only bought 2 because 1 makes my eyes hurt now
) Which is good because I have no idea where I put the disk...
The game works fine on windows 7 64bit and there are simple edits to get higher resolutions. There are a few issues with this, such as it being a vert- game the higher resolutions make it more and more zoomed in (so I only went up to 1680x1050). It doesn't allow alt+tabbing (theres a "windowed mode" option in the registry set as "0" but setting at "1" just stops the game loading for me. Might have to play around with that a bit
The game does allow 1600x1200 as one of the default resolutions, but I have no monitor with 1200 vertically to try this. Also note the menu/map section at the begining is locked to 640x480 whatever the game resolution.
Original 640x480
And
1680x1050 so you can see the zooming effect
(resized to 1600x1000 by host)
Anyway:
Dungeon Keeper ($5.99)
and
Dungeon Keeper 2 ($5.99)
Comes fully patched to 1.7, with the editor. There is no DRM, as there was only a disk check to start with. So you can play people with the same copy or just pay $5.99 again you cheapass!
Multiplayer worked fine on the home network. One slight thing is when you first try to launch multiplayer it will come up with the usual windows firewall notification box. But, as the game fills the screen and wont switch to the notification window you wont see this until you exit the game. So go to multiplayer > TCP/IP, search for games then exit the game. Allow firewall access then reload the game. For internet multiplayer i'm guessing hamachi would work fine.
Oh and while were at it. I hope War for the overworld (community made DK3) gets finished soon. So go bug them to finish it
Original 640x480
And
Anyway:
and
