Dual screens...
Looking at his sig, I don't see a nvidia card listed. I only saw an ATI offering. So someone with some ATI driver experience would need to assist him.
Desolate said:
I got a 9800xt ... ATI ;-/
Ok, your ATi control panel...
Either way you should have a control panel with a monitor tab.
There you will be able to clone, and use both.
No... I dont want that... I want it to be real whide screen like... not two of the same pics.
try http://graphics.tomshardware.com/graphic/20040216/
its older but most of it still applies..
most newer games will work with modified resolutions, you typically have to set it manually in a config file though..
the only game i havne't been able to get to work is Knights of the old republic (I and II).. and Rome Total work looks awesome on the battlefield but poor on the campaign map..
try http://www.tigerdave.com/wgl/ for a short list of work arounds, although not all games that will work are on this list, you just have to try it.
