There is $$$$$$$ICE_9 said:Specs on the system as well as pics please!!!! Their needs to be a special term refering to boxen that do >2K PPD.
Cost would be a good number too if you have it.
Yea....Folding MonstersICE_9 said:Their needs to be a special term refering to boxen that do >2K PPD.
"God Box" seems appropriate.ICE_9 said:Their needs to be a special term refering to boxen that do >2K PPD.
IanG said:"God Box" seems appropriate.
Is this a mac pro by any chance, or a server/workstation?
Roman79 said:I purpose "Uberboxen"![]()
ICE_9 said:How about "Marty Boxen" or a "FLECOM Boxen"?
unhappy_mage said:I like how that Tyan board ICE9 linked has an "inversed PCI-E x4 slot (w/ x8 signal)". Not sure exactly how that works. And why the JS drives? The KS or RE2s would be much better.
Running linux x64 directly on it? That's some nice PPD you got there...
zim01 said:2605 10.23/frame=2477ppd
3023 3.28/frame=2537ppd
5014
ND40oz said:Nice, looks like you made it there first, your maths a little off though, fixed it for you![]()
marty9876 said:and I'll fix yours.
2440 PPD + 2438 PPD= 4878 PPD
.....close.....
ND40oz said:Maybe I missed something, but it was originally posted 2477ppd and 2537ppd. Now granted I didn't go back and figure out the points per work unit versus time per frame, but if you did, atleast justify how you came up with two completely random numbers. I figured the math for the originaly ppd was correct and the addition was just wrong.
marty9876 said:not really completely random, just right near as I can tell.
ND40oz said:Marty, the problem is how you calculated the minutes and seconds, you said 10 min 23 seconds, it was really 10.23 minutes or 10 min. and 13.8 seconds. Zims numbers are correct, he's at 5000ppd.
ICE_9 said:What name are you folding under?
marty9876 said:zim needs to post logs, it impossible to get anything 13.8 second readings from long--- the logs are listed in seconds to beging with. How can you get fractional seconds from source in seconds?
marty9876 said:ND you must be running 2k3 on that box huh.
ND40oz said:XP x64, so close enough, same kernel. Haven't had time to mess around with a 64 bit distro on it but I plan to...just a little hard to run SLI in Linux at this point. Plus, which system do you think I play BF2142 on?![]()
I'd like to see some screenies of Zim's beast as well, maybe he'll post some Monday morning pr0n for us all.
