DFI Daishi said:you can do it, if you have the probes installed and connected. i don't know for a fact if TN has the probes and is paying attention to what they are telling her.
Why is it everone thinks that I am a scatter brain? I actually have 5 on the Innovatek and 1 of the Aqua Computer in-line temp probes. I intend to use them all and one of them will be modified to monitor ambient temps. The Aquaero can monitor up to 6 temp monitoring devices and control fans through the use of 4 fan headers. Assuming you know what you are doing you can even run multiple fan units off the same header. I can also program up to four different fan speed parameters for turning off, turning on, increasing, and decreasing fan speeds. I also have the equipment to monitor up to two different flows in my system as well. Hell, I have better diagnostic and control hardware/software for watercooling than many of the review sites (ProCooling excepted) I have come across lately.
One of the reasons I seem to propose some outlandish water cooling setups is because I have the hardware and software to completely monitor what is going on. I really don't care what conventional wisdom dictates because when you got this kind of stuff you can play around and try out all kinds of exotic design parameters
If you are interested in what the Aquaero can do then here is the manual. A couple of changes have been made recently: No more PWM of the fans as it is now back to analog. Fan header 4 can be reconfigured to use as a 2nd flowmeter port. New OS and firmware along with the AquaSuite software allows for everything mentioned plus way more features than you could only imagine.
