Dual NIC. Don't understand completely.
Mr. Stryker
I don't know how to get it to feed internet to my other device. Does it have to be a computer for the second NIC to give internet to? I know that you can get wires from two outputs in a dorm and multiply the bandwidth but is that the only thing for the Dual NICs?
You're trying to do psuedo-bonding of the connections?
It won't work. Because each device will have a seperate IP to route over. The only way this would work is if you rewrote how TCP/IP functions. Or had some sort of Bonded Gateway.
Even the expensive Dual WAN routers do not function in this fashion. It'd be AWESOME if they could do this, but there's no logical way. The only way to seemingly fake this is to setup a headend machine that handles both connections, and thats your gateway, but you're still only going to use one on the route out, or in.
You're on the right track. This would be a multilink or bonded config and WinXP on it's own doesn't support this. You'd need third party software then a switch or router that would handle it from there.
i dont think he is talking about setting up 2 ISP's into 1 system to use them both to get faster speeds
Are you trying to "share" your internet with other computers / PDA's etc etc ?
