txfeinbergs
- Sep 6, 2004
Guys, a quick question for you. Every DVI-D Dual link cable ad I have looked at states that the cable can handle a max resolution of 2048x1536; however, I apparently need a Dual Link DVI-D cable for a Dell U3011 monitor to get to 2560 x 1600. I know this monitor comes with a cable already, but I need an extra one for my laptop. What am I missing here? (or do you have a cable recommendation?). Thanks.
Here is an example ad:
Cables To Go - 5M DVI-D M/M Dl Digital Video Cable (Black)
THIS IS A BRAND NEW UNOPENED ITEM.
Description
Digital Visual Interface (DVI) is the standard interface for a high-performance connection between PCs and flat panel displays, digital CRT displays, projectors, and HDTV. DVI-D Digital Cables from Cables To Go deliver the high-performance, high-bandwidth interface needed for video displays of today while leaving headroom for the products of tomorrow. These precision-engineered cables are fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVD-D dual link configuration provides enough bandwidth for resolutions up to 2048 x 1536 and allows high speed digital transmission up to 9.9 Gbps.
Description
