Just rememebr to use a Crossover CableMr. Stryker said:It's sorta like a "switch" with 1 free port. You plut a CAT wire to the second port, and plug that wire to another computer. That computer will be getting Internet FROM that computer with dual LANs.
It's not a switch at all nor does it act like one in any way. The other reply to you was correct tho...if you plug it directly into another computer you will need a cross over cable.Mr. Stryker said:It's sorta like a "switch" with 1 free port. You plut a CAT wire to the second port, and plug that wire to another computer. That computer will be getting Internet FROM that computer with dual LANs.
Now you're talking Etherchannel. That largely depends on the OS you're running and whether or not it supports Etherchannel. It would also depend on the switch you're connecting to supporting that function as well.TheGamerZ said:on larger networks you could bridge the two connections for one (theoretically) faster connection
jervonics said:how do you use dual lan?
So you've made it that much easier to hack into your machine. Gee that's great.Sensimeli said:Heres a thought about what to use the extra lan port for. I purchase two IP's from my ISP. I'm on cable so the coax comes into the cable modem and then into a switch, that switch in turn connects directly to one of my lan ports on my gaming machine, and to a router/switch combo that provides Ip's and security for my home/private network.
Now this isnt all there is to it though. I have bound the 'Client for MS Networks - tcp/ip' ONLY, to that same lan port; before the router, from the first switch.
For the second LAN port on my gaming machine I use a line from the router with Bindings set to include 'File and Printer Sharing' AND 'Client for MS Networks-tcp/ip'.
This setup allows me to online game directly connected to the net with no router in the way and allows me to file share seamlessly across my home network, it works very nicely i must say. I can even run huge file transfers accross the home network while I'm gaming and it doesnt effect my connection speeds (at least not noticably)
As a side note I also run another router 'below' or 'inside' the first router for a second private network that I use for testing/cleaning infected or otherwise 'dangerous' computers and keeping them away from my machines.
Hope that sheds some light on an idea you can use both those ports for.
J
edit, just to clarify, I mentioned two IPs from the ISP, well one feeds my direct conection and the other feeds the router.
Fiber isn't a viable Internet option at the moment. There aren't any real applications that can tax current available Internet bandwidths much less standard 100mb Ethernet.jervonics said:ok thanks for all the replies. i was hoping to hear that you could run two CAT cables from a router into my machine for a faster internet connection. but it doesn't matter. does anyone have FIBEROPTIC to the home yet? the guy that hooked up my cable modem told me that it is the next level as far as connectionc to the internet go. he has been installing it in small test areas all over the south. does anyone already have this new technology? how does it copmpare to 5 mb cable?
