Dual graphic card question???
gearedout
This has probably been asked already, but I can't find the answer. On system with SLI capablity can you use the graphic cards independently. Say I wanted to run 4 displays... can you do that? Or does it only work in SLI mode?
When you enable SLI, you can only have one display. With SLI disabled you can have as many displays as each card supports.
is it possible to disable SLI without reconfiguring the board or the sli bridge? (.ie disable throught software)?
^^^ Right now, I don't think so. In the future, probably ;).
There's an option in the nvidia settings... "enable SLI" or "disable SLI". The default is disabled. With a restart, the change should be done.
I thought if your Video Card's supported dual monitor out that u could still use two monitors on the one card but Not the full four in SLI mode. I thought this was because you are basically changing Two cards into One with the SLI enabled.
Am I correct or do I need to read up on this stuff again?
