Dual EPS 8pin ?
jstanthr
What PSU's have dual eps 8pin connectors? im using an e760 classy board, and would like to use em both, but other than the enermax galaxy and evo, what others have dual eps8's?
ThX
JsT
Keep in mind that you don't actually need two EPS12V connectors to run the Classified. The second one is there for extreme overclocking, but the board will run fine with a single one.
i know it only takes one, but would need them both for my ln2 setup. the only problem ive ran into in looking is finding one that natively has 3 8pin and 3 6pin pci-e connectors as well. i'll probably endup getting another enermax 1250, its too much of a hassle to unbolt mine from my case for a bench session, was just trying to experience a different psu on my bench. when using ln2 i rotate graphics cards quite often between 2x 295's, 3x 280's, 4x 280's, 2x 5970, 3x and 4x 5870s, i need to get my hwbot acnt built back up for the i7 platform (havent done much "real" benching since my p4 ht days.
I see; didn't realize that you'd actually be doing extreme benching. If you're going to be using those kinds of GPU setups, then it would be a better idea to go with the Galaxy EVO 1250W than one of the Seasonics.
