- Feb 1, 2005
So, just in general, if a game is actually "using" both cores, what will the CPU Usage look like in the Task Manager? One core maxed, the other one at or near zero? Both cores around 50%?
I'm wondering because Company of Heroes and Quake 4 (who are both supposed to take advantage of dual core procs) both show the CPU Usage at 50% for each core. However, STALKER and FEAR, who also are supposed to take advantage of dual cores, show one CPU at 100% and the other around 0. The games run okay, but I'm wondering if it is just because my proc is at 2.7Ghz with 2 gigs of RAM and not because it is actually using both cores...
I'm not sure what the usage looks like, but I would see what kind of benchmark results you're getting with one core enabled or both cores. I never really thought about the usage, I was always more concerned with the raw performance.
When I installed the optimizer and double-clicked the icon from the programs folder, nothing happened. They state in the readme that there's supposed to be an AMD logo in the system tray to toggle game mode "on/off". I don't get that at all. Double-clicking the icon does nothing. I don't have the MS hotfix installed, just the AMD driver set (dated July 2006) and this optimizer.
The only game I'm concerned with is CS:S. I'm getting what most posters are describing as 'slowdowns' and choppy moving bots across the screen. Putting less bots in the game doesn't help and even setting the affinity to only use CPU 0 doesn't help much either.
Am I doing something wrong? Should I only be using ONE fix and not two?
System specs:
ASUS A8V-Deluxe
AMD opteron dual core 180
1GB Corsair PC3200XL 2-2-2-5
ATI X1600XT
WD Raptor 74GB set at RAID 0
I'm not OC'ing any hardware component and I have the most updated drivers for my BIOS, (no beta, just official release) video card (latest post is March 28th).
Any help would be appreciated.....Sorry in advance if I left something out.
I would use the MS hotfix if you're experiencing slowdowns (or at least try that also).
