Hi, first I'll give some background on my situation...
Recently, I bought a Corsair 2x1024MB pair of dual channel DDR2 PC6400 memory sticks (link) and when they came in, one of them didn't work (the system won't even POST if that specific stick is inserted). I don't have any fallback DDR2 memory, so I'm stuck with 1GB for the next four months until I'm away from my computer for awhile, giving me a period with which to RMA the suckers, since a) I'm not sure how long the RMA will take, and b) 1GB is better than 0GB
Anyways, I recently came across a deal for a different pair of memory sticks (2x1024MB, dual channel DDR PC5400) and I'm tempted to buy them, however, my purchase depends on the answer to the following question:
If I put in all four sticks at the same time correctly, i.e. I match up each stick with the right DIMM slot, will my system work properly, even though they're all dual channel? What about the fact that they're different speeds (or, what if they're the same speed?)?
Oh, and in case this changes the answer at all, here's my mobo and cpu:
Asus P5B-plus
Intel Q6600 (Kentsfield @2.4GHz)
Asus P5B-plus
