DS3R and Zalman 9500 Problem
I just put together my first computer last weekend. After about 12 hours I decided to replace the stock Intel HSF because it was making an annoying squeaking noise. So I picked up a Zalman 9500. It went on alright, but when I booted up the fan wasn't spinning properly. It would kind of just kick around a little periodically.
I had it plugged into the spot for the CPU fan and in the BIOS, the settings should have been fine. I got around the problem by plugging it into another sys fan port and it worked there. I've just been running it at full speed because I'm not sure if it will speed up enough if the cpu gets too hot.
Any idea on why it wouldn't work in the cpu plug but the stock intel hsf does?
Go into your bios and turn off thermal fan controls. Not sure what it's under on that board, but your fan should spin faster once the CPU heats up.
I don't know if the new Gigabyte DS3R has the same issue, but I've had the Zalman 9500 on my DS3 for abut 6 months. There is a particular quirk with this board where the cpu fan does not spin initially on bootup but does start up after a few seconds. No problems at all from this, but it did give me a minor heart attack when I first built the system and started it up:p
It seems to be working now in the cpu slot. I think you were right about it not working at first when it boots up. I think it also doesn't work of the fan control is set to auto. I had to change that from auto to PWM. Thanks for the help
