prototype_sx
- Oct 28, 2005
I have speedfan installed on my machine and let it run on startup and noticed a few weeks ago that my e6300 which normally idles at about 42 degrees suddenly started idling at 58 degrees. I reseated my zalman and reapplied arctic silver 5 about 3 times but the temps stayed the same. Just now I was going through trying to figure out what changed that caused the system to change temps when i recall upgrading from bios f10 to f11 shortly before noticing the difference in temps.
Long and short, I downloaded f10 just now and used @bios to change from f11 back to f10 and voila, temps are back to normal. Just puttin the word out in case it affected anyone else, also curious to know wtf could cause the cpu temps to go up by so much? The cpu usage would say 2% for 10 min after startup an temps would still be 58, I hit 70's under load! Glad I figured it out
