I just got through a few days of struggling w/ a cold boot problem on a DS3 Rev. 1.0 board, that started when I tried to use some new Crucial Ballistix ram. Keep in mind I'm just trying to keep a modest 400x8=3.2 / 4-4-4-12 overlock (and using F11 bios)!
Up until yesterday, there was NO combination of bios settings that solved the cold boot (I define the cold boot problem as a reset to stock settings after the computer was off > than 6-8 hours).
What were the last few things I tried before almost giving up, and chucking this board in the garbage (And I was really going to chuck it!!)?
- I moved the PCI-E voltage to 102, from 100.
- I pulled the CMOS battery for a while, then put it back in (I didn't use the reset jumper)
- I turned off "Hibernate", after turning it on about the same time I put the Crucial in (bad idea!)
- I may have made a few bios setting changes, but nothing I could put a finger on that would have helped.
Guys, I think it was turning off "Hibernate" that fixed the Cold Boot. It's got to be. The second best choice is move PCI-E up to 102, but it worked fine at 100 for 3 months. Does anyone know if Hibernate could have caused the cold boot?
I think the motherboard and ram are fed some juice, even when the power switch is off, but the PSU is plugged in. When you power on, the motherboard does something w/ the ram on boot, and that's what craps out; and it has something to do w/ hybernate. Hybernate perhaps sets up the ram to accept the ram dump to the hard drive, and that something did not like these overclocking settings being in place, hence the cold boot.
Anyway, the boards working now, hibernate is off, and I really don't want to do any more testing, for now, that could upset the current stability.
Actually, none of this really matters because a P5K Deluxe is going in the TJ09 as soon as the new board comes in.
Anybody want to buy, what now appears to be, an OK DS3 Rev. 1.0 board?
Mark
Mark
