I have a GA-965P-DS3 rev 2.0 motherboard, and have overclocked it to both 400x8 and 356x9. Currently, I'm running 356x9, and the system runs rock solid, sometimes for days on end, until I try a warm reboot (such as restart for software update changes). When the system reboots, it seems to choke on something, makes a change in bios and tries to boot a second time, then it just hangs there until I manually reset it. I then have to open the case and short the bios reset jumper and reboot. I then enter bios, restore the 356x9 settings and save/reboot. Most of the time this works right away, but sometimes it doesn't take on the first try and I have to go through it all again and short the jumper. I'm running Vcore 1.2750v, memory +0.3v, and everything else set to Normal. System idles around 35C. System specs are below:
GA-965P-DS3
E6600 with Scythe Ninja Rev.B
Thermaltake CL-C0034 NB cooler
4GB Corsair 6400-C4, manually set to 4-4-4-12 +0.3V
150GB WD Raptor main drive
400GB Seagate 7200.10 data drive
160GB WD1600JS backup drive
NVidia QuadroFX 3500
Ultra XVS 700W
Antec Sonata II case
Short of writing down all my bios settings, is there a way to retrieve them in WinXP to post here? I've got a few things enabled like DOS usb keyboard and mouse but disabled EIST, C1E, virtualization, smart fan control, and other typically disabled settings. This seemed to happen more often at 400x9, and when the case is closed (side latched shut) -- I thought it was the SATA cables getting pinched by the case door so I swapped them all out for right-angle cables but it still happens. I'd suspect temperature but it does happen sometimes when the case is opened and the CPU is running reasonable temps now. Any ideas?
Thanks!
GA-965P-DS3
Ultra XVS 700W
Thanks!
