amoeba1126
- Aug 5, 2006
When I was removing the CPU from the plastic clam thing, it popped out and dropped on the carpet. Thankfully, the plastic backplate protecting the cpu prevented the gold contacts from touching the carpet. I plugged in the CPU and it boots up fine and passed 5 minutes of 100% full load. CPU's will either work or they won't work right? Or is there some kind of middle ground? You guys think I will be ok?
