Drive Screws
Angus
Does anyone know where i can get drive screws, specifically the small ones that can be used with drive caddies.
They are small and mount flush, as opposed to the normal ones which stick out, those are to big and won't allow the caddy to slide in.
Thanks!
Those one's still won't mount flush, i have some of those also, the only ones that i have that will work now came with a chenbro rackmount case, but i need more of them.
Thanks though..
I didn't think it would be so hard to find these, but i am either blind, or they are not easy to come by
Those one's at IPC should work Good Thanks!
Any chance you know someone else who sells them? They want 20 for shipping 100 screws to canada :(
I have, on occasions where I have less than the total I need, used only 1 screw per side on those caddies (2 screws total). Are you going to be moving the system a lot? If not, it might be a cost-effective solution at least until you get a cheaper screw source.
It does not look like that kit has the screws that the OP is looking for. Well unless (s)he is talking about something different than I am thinking.
