wkearney99
- Sep 8, 2010
What's going to give me better performance in ZFS, direct access to the drives (through a PCI-x SAT2-MV8) or passed through on a PCIe-8x Areca 1260 card? I've got the choice of using either a pair of the SAT2-MV8 cards or a single 16 port Areca.
Most likely the connected drives will just be SATA3 7200rpm consumer drives, not enterprise. I'll probably only start with 4 drives in a raidz1 pool (possibly 6 in a raidz2).
I'm also wondering about using the 1260 to handle a RAID10 or RAID6 and pass that through to ZFS as a single volume. The idea is to let ZFS handle the compression and caching, while having the Areca card handle the redundancy (it has a 4gb module and the battery). This is for office documents, not transactions, databases or media.
And if I'm passing multiple drives through (not using an on-board RAID) then is it better to put the drives on different controllers? Is ZFS going to be able to get better performance by the drives being on separate controllers, or is the margin so small as to probably not matter much. Especially if there's 16gb RAM for cache and an SSD for the L2ARC (no ZIL planned at this point, SLCs are still expensive).
