Drive or controller?
4745454b
Toms is rather slow tonight, thought I'd try here.
I've been having some issues with a drive. The drive in question is a WD 320GB. (AAKS if my memory serves.) Its been slow and sluggish for awhile now. Doing some digging, I've come up with the following odd info.
Errors in the event viewer:
1)The driver detected a controller error on \Device\Harddisk1\D.
2)An error was detected on device \Device\Harddisk1\D during a paging operation.
I have quite a few "primary" IDE controllers in this machine, 3 according to the device manager. One of them has a single device on it, in PIO mode. I'm assuming this is the 320GB.
Used speedfan to read the smart data. Everything checks out fine.
Used the "data lifeguard diagnostic for windows" (WD drive checker) to test the drive. The small/fast test came back clean as well, I'll run the longer test while I'm sleeping.
Frankly, I can't decide what the problem is. Obviously something is messed up. I have a 7200.10 250GB plugged into my first SATA port, and the 320GB is in the next. The 250GB is my main drive, and isn't giving my any problems. Can a controller have only one port go down? Is it simply a glitch and I should simply put it back into UDMA? Is the drive toast? My motherboard/controller? I'm open to any ideas.
I see this is as slow as toms. Or is it this is a stumper of a question? Motherboard/controller is the P5K-E premium. It is also the wifi edition.
As you have surmised, there's your problem.
This is usually a HDD or HDD cable problem.
If your drive passes the long HDD test, I would put the controller back to UDMA and change the SATA cable.
