I just back up my system by creating an partition image using Acronis True Image Home 9 and write to a DVD. I then use this software to create a boot cd.
When I booted from the CD and got into Acronis True Image, the sofware failed to detect any harddrive (SATA).
I did some research I found the following...
"Drive Image 7 will have problems finding the image file if the image file is on a HD connected to IDE3/SATA that is controlled by a seperate controller chip such as promise/SIS chip."
How do I fix this issue? I have Gigabyte DS3 board and Western Digtial 250GB SATA.
does this board has a separate controller which prevent Acronis True Image from recognize it?
thanks,
thanks,
