DRAM LED on mobo lights red.. need help
I have a DFI LanParty nF3 250Gb motherboard and I had just put a new 1Gb stick of ram into the slots, and the DRAM LED on the motherboard lights red... as the manual says, this mean there's electricity in the ram slots and there's a problem, I have no idea how to solve this problem, Some assistance would be great.
Does your motherboard support 3 RAM sticks? Also check your voltages to see if theres too much or too little power going to your RAM.
Are all your RAM slots filled? If they are it probably won't take that much double-sided RAM. If not, I'd try bumping your voltage a little bit in Bios (take the stick that doesn't work out).
yeah im running only 1 slot, the first slot. I tried grounding myself before installing, still lighting up..
Are you sure that the stick is okay? Any other boxes you can test it in? I suspect it's a fubared stick of ram.
fubared? Yeah i think the stick is fine, alright after opening and then closing the case, i started feeling some electrostatic (like the hairs on my arms were coming up) next to the acrylic window, there's electricity going everywhere, i dont know where it's coming from
also, i think it might contribute to the problem that my POWER LED and HDD LED is not flashing in the front..
