WhyYouLoveMe said:
Hey, he's trying to learn
WhyYouLoveMe said:
Dreamsbetray said:if i select 400mhz in bios for 3200 the ram will work but i wont get full speed of 3200 right?
if i select 400mhz in bios for 2100 i will burn my 2100 stick right?
Dreamsbetray said:hey lop u said if i select 400mhz dram frequency my cpu and dram will run out of sync u were wrong u r dumb the other guy told me to select 400mhz coz my cpu effective clock is 400mhz he says if i select 400mhz for 3200 my cpu and ram will run at sync.
there is no reason to use the 400MHz DRAM setting, unless you intend to remove the 256MB DDR2100 stick and only use the 512MB module.
You should only use the default or 266MHz setting if you intend to use both sticks simulteanously. However because your CPU's frequency is quadpumped for an effective speed of 400MHz. For best performance, I would recommend you remove the 256MB PC2100 stick and use only the 512MB module, then set the DRAM speed at 400MHz so that your CPU and DRAM runs in sync.
