Dreamsbetray
- Dec 27, 2005
i went in to bios saw this dram frequency thing now i have 3 option to choose 226 mhz 333mhz 400mhz which should i select?
I really don't know. You don't want to use a divider, so generally you want it at the same speed as your FSB (100mhz). Is this a homebuilt system?Dreamsbetray said:lets just say im going 2 use 3200
so what should i select in dram frequency?
i bet 400mhz right?
Dreamsbetray said:r u sure i can use 2700 and 3200 ddr ram?
r u sure i will get thier real speed 333mhz for 2700 and 400mhz for 3200?
seveal peopel toldme my mobo wont support 2700 and 3200
all jews i meant
Dreamsbetray said:no its not home built its acer aspire b300 model
i posted my mobo model number if u want it anyways
i really want to use 3200 and also want its real speed 400mhz
y i cant use that speed i mean i have option to select 400mhz is this not mean that i can use and get 3200 real speed?
Dreamsbetray said:if i install 3200 and set dram frequency to 400mhz what will happend?
Dreamsbetray said:can i set cpu frequency just like i have option to select dram frequency?
Dreamsbetray said:im sick waiting and typing in forums plz give me ur msn or yahoo id so we can chat on messanger![]()
Dreamsbetray said:what if i dont have auto option also tell me where to look for cpu frequency in bios?
Dreamsbetray said:3200 ram speed is 400mhz or maybe 200mhz and my fsb speed is 100mhz
Dreamsbetray said:3200 is 200 fsb and my cpu is 100 fsb is this mean i wont get 3200 real speed?
i dont have auto opetion in dram frequency i have these threee option 233mhz 333mhz and 400mhz
can u plz tell me how to change cpu frequency or ratio do i need to change it if i use 3200 ram?
Dreamsbetray said:Effective Clock 406 MHz
whats that?
Dreamsbetray said:liek u said 3200 double is 400mhz
right now im using pc2100 133mhz double 266mhz but im only getting 133mhz speed![]()
lopoetve said:divide by two to get the bus speed (give or take a few mhz)
What are you talking about? 133mhz speed in what?
Dreamsbetray said:i will drop 3200 but can u tell me what should i select in dram frequency section?
266mhz
333mhz
400mhz
lets say if i select 400mhz will i get the full speed of the ram which is 400mhz?
Dreamsbetray said:i am using 256mb ddr ram 2100 in bios dram frequency set to 266mhz
one small program in windows telling me that my memory speed is 133mhz
Memory Module Properties
Module Name Infineon 64D32000GU7B
Serial Number 0226E713h
Module Size 256 MB (1 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC2100 (133 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Highest CAS Latency 2.5 (7.0 ns @ 142 MHz)
2nd Highest CAS Latency 2.0 (7.5 ns @ 133 MHz)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer
Company Name Infineon Technologies AG
Product Information http://www.infineon.com/cgi/ecrm.dll/ecrm/scripts/prod_cat.jsp?oid=-8003
Dreamsbetray said:2100 256mb is 133mhz
2100 512mb is 266mhz
is that correct
Dreamsbetray said:i am not saying that i will run 2100 at 400mhz
i was asking that if i install 3200 ram what should i select in dram frequency?
if i select 400mhz will i get the full speed of 3200?
