Downloading entire threads?
Status
Not open for further replies.
DD_nVidia
Hey there, I'm looking to see if this is possible / allowed.
I'd ideally like to download a few entire threads from the forum including any images so that I can use them for reference in re-doing my room
Is there an easy way to do this? Or is there a way at least I can just get the images if not the text? (Images being the main thing however the text would be helpful too!)
Not to my knowledge, but you can cut and paste pages into a Google Doc and it will grab and insert the images and/or links.
Smart man! I don't think I have ever used that feature the entire time I have owned this board.
I use "Screengrab" on Firefox. It will allow you get the full page snapshot or sections if you choose. Just do a simple right click on the page and your options come up.
There is a way but maybe you don't feel like trying it?
OK, KILLER_K. What is this way that you know? And why wouldn't I wnat to try it, IF it met my requirement to download an entire thread at once, not downloading page by page of a long thread?
You can change your view options to show more posts/page of a thread. That's about the easiest way to do it afaik.
It might just be easier if you use something like httrack to rip the thread, though you may have to bulk edit the html files it spits out to make page buttons work.
Status
