Is it just me, or does that look like a Hazro?
Either somebody at the company for some inexplicable reason decided to stretch the image of the monitor for their teaser graphic, or the DS 30" is roughly a 2:1 ratio monitor, not a 16:10! Ok guys, we get it--it's a widescreen. No need to exaggerate.
Is this monitor worth waiting for?
Is this monitor worth waiting for? Or if you could get your hands on a Dell 3007-HC, would that be the better option?
decisions, decision
so if it's like the Hazro HZ30W, good or bad choice ?
Is it just me, or is there only one single input on that thing??![]()
Assuming it's the Hazro HZ30W re-branded, it would only have a dual-link DVI input.
will this thing have the anti-glare coating that causes "glittery dirt" on the screen?
What kind of video card does a person need to run this monitor?
how does this compare to the dell 007-hc
It's an LG-IPS panel. But only a single DVI input? nothing else? No thanks.
It must have no scaler.
Low input lag ftw
