waterlogged
- Oct 11, 2007
You would have to replace the flow meter inside the aquaduct and make too many modifications to the base to increase the ID. The unit works like a champ the way it is.
You can either replace the flow meter with the shipping version from Aqua Computer or drill out the existing flow meter to 6mm. If you do the second item you will have to calibrate the flow meter with a meter bucket. The holes in the Aquaduct base are easily 6mm in width last time I looked in there. Every little bit works! The current Aquaduct's being made have the 5.6mm flow meter inside them.
