Sorry that I have been gone for so long. This thread reminds me of the old days.
Uggh, I'm going as fast as I can, testing is a chore. And yes, it is a REAL system I test on. Have made a new discovery however. Some reading plz.EXACTLY! Since nobody has the passion to test all of the blocks out there right now, we must rely on actual user findings........
I have never been a fan of plastic topped blocks. I guess it is good for showing off your block and checking on your sea-monkeys.
Did anyone ever test this thing out for themselves? Nik? Ranker? I'm not rushing you, but I would like to know.
Under what conditions are you looking for test results?
I just was looking at the AC site and I think people are getting confused about what the testing was showing. It is not showing CPU temps! What it is showing is the difference between the CPU temp and the water temp. Obviously the lower the difference the better the cooler is removing heat, right?
AC Forum in English
linky
Third, Kelvin, why Kelvin?
Because Kelvin is used for temperature differences.
It is not that Kelvin you are thinking of![]()
Sales != performance R1ck, I would think you would know that by now. Especially when there are enough people who watercool on looks and brand and are perfectly fine with losing a bit of performance here or there. Sharka was bound to sell out quick before any substantive testing could be done.
Now the question is can they get a good quantity in stock before the first review site releases the results (Sharka sent blocks to at least one US site for reviews).
Well the loop is up (for now) and according to coretemp, my quad core is giving readings that are interesting....
Core 1 - 38c
Core 2 - 40c
Core 3 - 35c
Core 4 - 34c
I am going to introduce a new res (right now I am using a nikhsub1 clear tube res) this weekend and will do a few remounts to see if the temps stay consistant. I almost wonder if a "bow" to the base would increase performance. Flow appears to take a good hit as the water is not smashing against the opposite side of the res like a fuzion did. The other difference is I also have a EK 8800 block in the loop too so I don't know what kind of hit the flow takes just from that block. I am thinking of placing a second DDC in series to see how that affects the loop.
These temps are idle with a stock Q6600 but am getting 54-58 (depending on which core) on load with TAT. Only one mount so not sure if this is the optimal mount or not. I plan to do several this week end when I install the new res. So far so good though...... Runs quite as hell.
Agreed, mine is loading at 55C at 3200 @ 1.41V under a Fusion.I'd remount... I'm loading at 58 with my chip at 3400 1.5v...
Your EK is known to be fairly restrictive.Flow appears to take a good hit as the water is not smashing against the opposite side of the res like a fuzion did. The other difference is I also have a EK 8800 block in the loop too so I don't know what kind of hit the flow takes just from that block. I am thinking of placing a second DDC in series to see how that affects the loop.
That said, the DI block IS restrictive because of its design, far more so than the Fuzion. Look at how its two impingement chambers work: instead of using the loop's initial velocity to smash the water against the HS (think direct impingement: Storm, Fuzion, Apogee, etc), they build up a pressure chamber straight off the hose and then use this pressure to "squeeze" the water through the jets- this is very reminiscent of the Fuzion GFX block. This chamber MUST be restrictive, or else it wouldn't succeed at building any pressure: no pressure, no impingement- the water would just bleed/seep through the jets and keep flowing linearly. One stage of this is restrictive enough, but the DI links two of these in a row. Fortunately, the impact is less pronounced in the second stage due to the loop already having lost a great deal of its power, but it is still affected.
Do you have a DI block?
No... I don't think so. But it makes decisions.
Care to explain your last sentence ? Doesn't compute
No, I have a Fuzion. But I was raised by two engineers, one of whose degrees is in fluid mechanics. I know that doesn't qualify me per se, but it definitely gives me some insight.Do you have a DI block?
LOL. What the hell? Did I really post that?!
Ugh... I meant "But it makes sense"
I would be really interested in seeing results with a DI block and a Fuzion GFX in the same loop, but in parallel. They are both high performance (or have the potential to be- I haven't seen any definitive tests), but everyone seems put off by how restrictive they are. Running them side-by-side should offset this significantly.
I understand your point, but I believe that both of these blocks are much more dependent on pressure than they are on flow rate (within reason, of course). Your 50/50 distribution is also based on the presumption that they are equally restrictive, which I don't think they are.For someone who is trying to qualify himself in topics relating to fluid dynamics you have a very poor understanding of the serial/parallel relation in terms of watercooling.
Yes while putting the components in parallel will lessen the overall restriction to the loop, it will most likely put lower flow rates through each of the two components. The lessened restriction will not be enough to overcome the fact that the flow is now essentially split in half between the two separate branches.
Splitting components into parallel is best served for items that don't have drastic improvements with increased flow. Splitting those parts into parallel will increase the flow for the other components in the loop that are placed in series with it.
I doubt the DI block is as sensitive, though I can't find a chart for it.
I'm not so sure about that. As Cathar pointed out over at XS (about this same block, no less!), too little flow will affect the jet speed.It is well known that AC does not build blocks that don't well under low flow........ I would say the block is engineered to work at best under 1gpm.
I don't know where the cut-off is, but there is definitely a point where the flow rate is TOO low. Sub-1gpm may be enough, but personally, I'd try to stay in the 1-1.5 range.
Did you lap the block or CPU? I think a few guys at XS said their blocks came in concave, so it might not be mating with the IHS fully.Agreed but you must understand that AC equipment is made typically ran with mulitple blocks (ie. 2-6 blocks) per loop all driven off a Aquastream pump. With that in mind, I doupt that AC would care about flow above 1gpm when designing a block. That doesn't mean the block won't perform better at 1-1.5gpm, just got to put yourself in the mind of the designers.
What I find interesting about this block is why two cores are running so much cooler than the other two...... This has been consistant across mulitple mounts.
]http://i7.photobucket.com/albums/y255/rickcain/Computer Stuff/distockonquad.jpg
