Double check me before I order
toyopl
About to order new rig, and haven't put together pc in 7 years, been on gaming laptops.
Can you double check if everything makes sense ?
This is mostly for gaming, never OC'ed before but I am willing to try it out with this rig.
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W
CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML16GX3M4A1600C9
EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Asus VG236H 23" Full HD 120Hz 3D multimedia Height & Swivel Adjustable WideScreen LCD Monitor w/nVidia 3D Vision Kit hard bundle
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Corsair Obsidian Series 550D Black Aluminum / Steel ATX Mid Tower Computer Case
Crucial M4 CT256M4SSD2 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
If you are interested in OC'ing, why are you going Ivy Bridge? Unless you plan on changing the TIM between the heat spreader and the actual chip, you may have some serious heat issues trying to OC. This has been fairly well documented to this point.
For reference, I have an i5-2500k that OCs to 4.8ghz on air... easily....
I would go with an aftermarket HSF, 212 evo, dh14(pricey), H100/920 for all in one water cooler, etc.
The new IB does run hot, but really only when overclocking past 4.5 or more voltage(varies). I have the SB @ 4.8 1.38 and it runs cool, but if I were to buy a new one now it would be IB.
I am still not entirely sure what all the IB clamor is about. The IPC improvement is almost negligible. I would take a cool running higher OC SB vs the IB processors at the moment.
Yeah, it depends on if you want to OC high on the IB(4.5+).
If you want 5ghz+ then yeah, SB might be better. hehe
Some of the peoples temps were really high on IB, and they were on good water, so just depends.
I'm not gonna do crazy overclocks, just a little bit to see what the hype is about.
I'm the type of person that will buy gear, put it together and don't touch anything for next year or two.
But I said to myself that if I'm getting desktop I have to try a little bit of overclocking, so I'm guessing small OC will be fine with Ivy for temps.
Yes, but even on my kids stock system, I always ran an aftermarket(cheap freezer 7). It keeps the inside case cooler since it sucks air and pushed the hot air out the back towards the rear fan or top fan, making a quick exit out of the case. The stock hsf just swirls the hot air around and hope alot exits out of an exaust fan someplace.... just my 2 cents... :)
Oh my comment was directed ttowards the guys up top saying I shoul've skipped Ivy cuz it runs too hot when Oc'ed.
I'm actually looking for cooler right now, thinking about Geil Tranquillo.
