Double boot problem
forrehmmnd
Ok, i have the MSI p35 neo2 FR, which is known for double booting, and for some reason, it double boots all the time. It only used to do this when the power supply had been turned off or unplugged. Now it does it everytime i try to turn the computer on. Its just a nuisance. It just randomly started doing it, without any changes to the system.
Is it a concern, or should i just deal with it. Is there anyway to fix it ?
Usually a BIOs updates gets rid of the double boot problem with Abit and Gigabyte motherboards.
Hmm..well then not much you can do then I guess. The double boot problem isn't damaging to your hardware. Sure it's annoying but not a problem to worry about.
Ok, yeah its just annoying. I guess it doesn't matter as long as it doesn't hurt the hardware.
