AOM said:We'll PLink....pretty awesome setup I must say......I think you said that at least a 1000:1 contrast ratio was great to have.....what about 15000:1 ?....I just got a projector from my work for Nada...0.00 dollars....yeah I know lucky me....anyway the speces on it are here crtcinema.com/necspecs ....it's the NEC PG6000 ....pretty nice from what I can find out....does up to a 300" screen.....I have a 10 FT one that came with it for nothing.....believe it or not where I work was going to crush a building where this thing was and they said they had no use for it and that I could have it so ther you go....it's only been used about 10 times and is only about 2 yrs old.....anyway....it should be awesome.....nice car too....looking at buying one myself in the next couple of months...I'm in your field Computer Networking...working on getting my CCNA in September
...yes 1080i is better than 720p...not by much but it is true HD....I disagree on the cable talk....I sold Monster Cable for 4 yrs and have it on all my equipment....yes it is more expensive but their is a noticable difference between it,cheap crap...and self built cables....especially on large screens like the one you have......I've tried them all and compared them on large screens and you do notice a difference.....I can't blame you for not spending the money though b/c I probably won't either when I set mine up...it is lots of loot just for cables...anyway....I plan on doing the same thing that you are...I have DOOM 3 and FarCry but have yet to play either b/c of my current pc....I have an Athlon XP3200+ Barton....512mb OCZ PC 3200 but a doodoo Geforce 3 64mb card...so I'm about to build a new pc for my gaming so that I may enjoy Doom3 in all it's glory ....as far as subs go....look no further than Sunfire.... sunfire.com ...you'll get no better than these...period.....let me know what you think of the subs and the projector....and my setup.
1386x788 is ~16:9 widescreen format, so 720P would be near perfect (the 2nd # in a A x B resolution is how many horizontal lines there are making up the height of the image)EQTakeOffense said:Ok, my basic question is simple, but complicated. How does projector resolutions work? What I mean by this is.
1. If the native resolution is 1386x788 for the SONY VPL-HS20 then how do you get different resolutions such as (when it says singal compatibility) 480i, 480p, 575i, 575p, 720p, 1080i, and computer resolutions VGA 640x480 through XGA 1024x768 and 1280x768?
Basicly, I don't understand how projector resolutions work exactly. Can I play games at 1600x1200? Or, can I only play games at any of those signal compatiaility resolutions?
Also, are the resolutions dependent on the signal, thus 'signal compatibility'?
Ex: A DVD player has output to 720p. When I plug the DVD player into the projector and select the right input the projector will switch to 720p. But, when I swtich input to my computer and I'm going to connect it via VGA the projector swtiches resolutions to 640x480? Obiously, 720 is better then 640x480 which is why you 'hack' the ini files and such to get the computer to dispaly 720p?
Jake said:1386x788 is ~16:9 widescreen format, so 720P would be near perfect (the 2nd # in a A x B resolution is how many horizontal lines there are making up the height of the image)
Anything else is either scaled (stretched or shrunk) or they just show black for any unused pixels.
nope 1386x788 would be the highest resolution you could set it at. Similar to an LCD monitor. You have a fixed number of pixels, use em or lose em.
You could do 1024x768 but you would have black bars on the left and right (if the game doesn't support widescreen modes)
Yes they are, I'm not totally up on this but I'll give it a shot.
To do any sort of HD signal you need to use either component or VGA/DVI. S-video or composite are 480i (can they do progressive?) Your source unit (dvd player or computer) will attempt to tell the pj what rez it wants to use.
figgie said:Plink
since you are rolling money bags... forget da-lite and go to the top dog.
Stewart Screens.
Ain't nothing (save for screen research) that will be better.
figgie said:The thing about a native 16x9 display is that when you display a 2.35:1 movie (lord of the rings, star wars, and a whole sleew of other movies) si that you lose resolution on a 16x9 display. Let say that the dvd player is outputting 1280x720p signal. So now you are using 1280 pixels wide x 546p high. You lose ALOT of resolution.
am only running doom 3 at 1024x768 because of the lack of true 1280x720 support. I have ran it stretched at 1280x720 but its annoying. So I will wait for official support
plink said:Mmm, not exactly. The projector still displays the 16:9 resolution, but just adds black bars on the top and bottom. So its still displaying 1280x720 but now part of the width is black bars. You would not gain any resolution by buying a 2.35:1 widescreen projector as the resolution of the dvd is still 480p. which is a 16:9 ratio. All that would do is cut off the black bars for you. So its basically pointless.
EQTakeOffense said:So....
You said:
Since, you're not running at the native resolution, you have black bars around the game, correct?
AOM said:Real funny PLink....lol......if you've ever read any reviews on that series of Infinity Speakers you'd know that their highly recommended for the price range ....and if you have the money to spend...you really can't get much better sound quality than the Infinity Prelude MTS series....but they are outrageous in price...but I know you were just joshing me...yeah...the receiver is awesome...but to be honest since I just got it a couple of months ago I really haven't even had time to break it in yet.....I haven't got to really sit down and use it a whole lot and check out a lot of dvd's or anything....but I've also been kind of waiting to get the projector setup so that I can view them really well also
.......I looked on the link you gave me but I couldn't seem to find anything on that projector on that site.....it might be b/c it's a professional grade projector.....it was used mainly for Power Point presentations and things of that nature...when they actually turned it on.....really was a waste of money...but big corps tend to do that......good for me though......question for ya.....is the screen you're getting wall mount for permanent display or does it retract into the ceiling? The one I have is going to be mounted in the ceiling and it is controlled by remote up and down...and it closes off into it's housing flush with the ceiling.
figgie said:what i said was
"Then if you put in a 1280x720P signal..you will effectively only use 1280 out of the 1386 pixels wide and 720 pixels out of the 768 pixels high.Meaning in an LCD display you will have "black" bars on top and bottom of the pj and also some on the side." on a 1386*768 display
The 1280x720 on a 16x9 is still being used but beside the 545 pixels being used to display content of the 2.35 title. The other pixels are still being used but are displaying nothing more than black. Hence with a panamorph lense. You use the entire 1280x720 panel which if you viewed without the panamorph lens looks like all the people are anorexic thinThe lens actually corrects this and sends the image as a true 2.35 image using all 1280x720 pixels instead of 1280x544imagecontent+175 pixels worth of black bar.. Trust me. The theaters have been using this technique since the early 70's.
AOM said:Ok the screen I have is a DA-Lite Model No. B801-93 Serial No.35148...8X10...this is on the side panel of the screen....I just looked.....forturnately for me....I work from home 3 days a week on my computer and 2 days I go to the office...so I can do pretty much as I please all day....I only go in if there's a problem......going to look for their site and see if I can see how good this screen is.
AOM said:We'll it's not the highest quality screen compared to the newer models but it's still very nice....found it on a search.....this is what it has as far as features.....Matte White, Glass Beaded,Video Spectra 1.5 and High Power.....it's cleanable with mild soap and water...so that's a plus when you want to clean it.....
so considering what I found out...it should be pretty good....hope to get it up in the next month or two....going to take me a while ...b/c I'm going to have my ceiling redone in that room completely so I can have the projector and screen both motorize down out of the ceiling and then back up out of view when I'm not using them.....as soon as I get it up and running I will be sure to post some high quality pics so that you can see the setup.....and your speakers are only 2nd best....mine are the best ...lol
Movieesa said:This thread might be somewhat about Doom 3 but I know you guys bought those set ups for Pokemon the movie. Come on, admit it!!!!!
Advil said:Does anyone else think it's plain stupid at this point to have all these issues with various widescreen formats? Lets put on some rose colored glasses for a moment and assume we live in an ideal world.
Why can't the LCD projectors be built with a pixel count high enough to display maximum resolution of any normal video source that currently exists? And why can't the image and bulb both have have mechanical adjustment that adjusts for whatever res and width you are using? Photocopiers can do it.
Or at the very least why don't they all come with panamorphic lenses to alleviate the problem of 2.35 widescreen?
Computer monitors automatically adjust their res, refresh rate, and user defined screen positions. Projectors should be capable of that as well. As a matter of fact, these same complaints apply to all rear projection TVs.
khaosman said:That is beautiful. What really made me excited is that your audio is as good as your picture![]()
EQTakeOffense said:So, in regards to my resolution question.
You make the games fit around the resolution. Read: You change the games resolution to match the projectors instead of in a CRT where you change the resolution of the screen to match the game. Correct?
bjork said:Omg Omg Dood Joo Are The L33test! Can I Cum Over And Wax Joor Car!? Is Joor Gf Hot!? I Bet He Is!
Woot@!!!!1!
Stumbo said:Im on a big screen too (72"), and with 5.1 surround sound. I run doom at 1360x768 through my Nec6pg CRT projector, very sharp, very fast, very very pretty!
I need to upgrade my video card so i can run at high detail level, however
