This is not the case at all. There has apparently been a break down in communication between Xilikon, Team 33, and the DAB. I recently posted a rant in the beta forum about p2684 and Bruce (site admin) quickly sent me a PM asking me to talk to my DAB Representative. I replied back stating that I had assumed the DAB was dead but Bruce informed me that he knew otherwise and that Xilikon had essentially "given up" but declined to comment further. I have always had a good relationship with Vijay, so I immediately sent Vijay an email and he confirmed for me that Xilikon hadn't participated much at all in any of the recent discussions.Donor Advisory Board can only be called stillborn and a dismal failure.
Vijay Pande said:Hi,
I'd love to get your input in the DAB. I'll send an email to Bruce and cc you to get you involved.
It's surprising and a bit disappointing to hear that Xilikon feels like the DAB has been stagnant. I think the other DAB members would disagree. In fact, I recently asked them if they're happy with the DAB and the progress we've made and got only positive responses.
I'm not sure why, but it looks to me like Xilikon's participation in the DAB has been stagnant (he hasn't posted there in a long time). I'd love to get participation from your team. Thanks for bringing this up.
Vijay
oh geez we've been down that road....Otherwise the really hardcore may look to automate the jettisoning of 2684's from their machines.
The question is where and how much of a points difference would be acceptable?I would honestly be comfortable if bigadv PPD were normalized somewhere between 2684 and 6901.
I can live with the differences on all units except 2684 and I believe I can speak for musky on this as well. The small differences on the other units seem acceptable. However, I don't know if benchmarking is the issue with 2684 as it DOES take long to fold it so it makes sense that it should be valued less given the goals of the QRB system. In my example above, it takes 15 hours longer to fold a p2684 compared to a p2685 but I agree that the points difference seems exaggerated. As I said above, I don't know how to do the math to determine if the 15 hours difference between a 2684 and a 2685 for a points difference of 26K PPD is an appropriate difference in points or not.I am strongly of the view that we should use the 2686/2692/6900/6901 as the baseline, and correcting up the 2684, and if possible the 2689 and 2685.
Reasons are mostly psychological - not great for donor morale to cut the future points - people are used to discussing max points capacity of their rigs. People have made relative purchasing decisions based on capacity. I can't think of a better way to piss off more people than devaluing what they are used to. Forums will be overrun with all the "why did my machine get slower". Any "thanks for fixing the 2684" would be drowned out by the howls...
That benchmark sounds really awesome. I hope that becomes a standard piece of software like HFM.net
Vijay Pande said:To make this very specific: what do you think the points for P2684 should be? I can run that w/Prof. Kasson to see what he thinks and post his reply.
SMP work units are benchmarked on an X3450 which is similar to an i5-750 but has HT so it's an 8-thread CPU.They claim bigadv is benchmarked on the same system. I just don't see how that could be possible.
Guys, I've presented all the numbers and opinions to Vijay regarding p2684 and here is what he wants from us:
So, how do you guys think it should be valued? Now, before you guys answer, it can't really equal exactly the same points as P6901 or other bigadv units can it? It DOES run a bit slower after all so it should be valued less, the question is how much less. As I said above, I don't know how to do the math to determine if the 15 hours difference, in my example above, between a 2684 and a 2685 for a points difference of 26K PPD is an appropriate difference in points or not.
So, how do you guys think it should be valued compared to other units? Be specific but not greedy.
That would put it about equal with 2685 then, correct? They may find that to be too much. How would you, and others, feel about 12K base points?I find 13500 base pts for 2684 to fall around 5k pts less than 6901 and be pretty reasonable...
Its in the middle of the range I calculated, so I'd be fine with it.
H.
There are less WUs that are supposedly "unbalanced" than there are those that fold consistently with similar PPD. 2684 is the only bigadv that people have an issue with. 6701/6702 are in hibernation at the moment and may or may not come back. Moving forward, we are also discussing how to catch perceived slow WUs before they leave beta testing such is the case with the new 7200 unit.If 2684 is rebalanced, the outcry will begin about 6701, and after those the 111xx monsters.
It should be worth exactly the same as a 6901 in terms of ppd. 2685s and 2689s should be re-adjusted as well. Patriot hit the nail on the head as to why:That would put it about equal with 2685 then, correct? They may find that to be too much. How would you, and others, feel about 12K base points?
I will not be happy with the points system until this is done. The compomise crap is just that - a compromise, and crap. Why does Stanford think these "points" are so valuable?? This really seems like a no-brainer to me...make your contributers happy at virtually zero cost to you...for some reason... be it the wu is more complex requiring more work or coding... the cpus are still running full bore... they tend to use more power on that unit... doing more work for less ppd doesn't make sense.
technically, that's a fallacy.for some reason... be it the wu is more complex requiring more work or coding... the cpus are still running full bore... they tend to use more power on that unit... doing more work for less ppd doesn't make sense.
So all bigadv units should equal the same PPD on the donors system and let the QRB reflect the faster systems.It should be worth exactly the same as a 6901 in terms of ppd. 2685s and 2689s should be re-adjusted as well.
not necessarily. you could look at it that way, or you could look at it another way:So get rid of the QRB then, because that is where the problem is.
There needs to be a compromise between work done and time to complete. A harder WU that takes longer to finish should scale with a less-intensive WU that's quick to finish.
