- Jul 21, 2009
So I'm going to do a really, really cheap build. The fact that I'm bringing a HD and a MoBo into this should help keep costs down.
This computer is going to do a grand total of two things. 1) Sync my Dad's Zune 120, and sync my Dad's iPhone. I may occasionally be used for web browsing. But I seriously, seriously doubt it would see any other use. In other words, Firefox, iTunes, and Zune.
My budget is fairly flexible. Definitely under $400, but hopefully lower than that. As cheap as possible without sacrificing usability is the goal.
US. Lafayette, LA. No Microcenters around me. I prefer Amazon since I'm a prime member, but if Newegg is cheaper, I'll buy there.
CPU, RAM, Case, Power Supply, Monitor
Its going to be an 1155 Mobo. Either a P67 Sabertooth (if so I'll bring the GPU; don't worry about it) or a Z77 pro (it was free).
I also have a 1.5 tb HDD. This will be the storage drive as well as the boot drive.
6) Will you be overclocking?
Nope.
Don't have one yet. Since cheap is the goal, I'm looking at this. It isn't the best, but again, cheap is the goal. Its good enough for the purpose of this computer. Dad's eyes are getting weaker, so going full 1080 isn't going to happen on anything less than 27"...which is expensive.
Good question. I'm aiming for the next two-three weeks. Meaning at the end of two to three weeks, I want to have a computer built. When it actually gets built depends upon the cost of the computer as a whole.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
N/A
64 bit Windows 7.
___
Here's what I'm looking at:
AOC 1600 x 900 Monitor - $103
Celeron G530 - $47.41
4 GB of Corsair RAM - $22.99
430w Corsair Builder Power Supply - $40.68
NZXT Source 210 Case - $39.99
Total: $254.07
I want to reiterate, the goal here is to maximize value. I'm sure I could get a better case, more RAM, better monitor, better processor, etc, but I don't think it would be an effective use of funds. I'm most tempted to up to 8 GB of RAM, but I don't think that would be a wise decision.
Nope.
N/A
64 bit Windows 7.
___
Total: $254.07
