same here, but I'm still hopingI'm going to guess not since under the hood they are about the same thing.
haha yeaGo for it!
If you hit a wall you know why though.
oh interesting, I didn't realize thatIt not the number of GPU that the limit, its the number of monitor outputs.
Once you hit 8 monitor outputs then Vista won't load anymore drivers.
The trouble is that on a 9800GX2 card, Vista sees 3 monitor outputs per card, the two DVI's plus the HDMI output.
XP only sees the two DVI's.
If you could disable the HDMI output under Vista then you could get upto 8 GPU's, the same as XP.
So its a question of how many outputs Windoze7 sees per card as to how many GPU's you can run.
Luck ..............
Luck ..............
I can see how that'd be frustrating, since I guess only two 9800GX2s (or GTX295s?) would be utilized fully? The other one is just one GPU?
That'd be a ripoff.
Does Server have this same limitation? I wonder what the reasoning behind this is.
the insane folders that run more then 4 gpus at a time are a small percentage of winblows users..
I'm not insane..... just demanding![]()
Luck ..............
Perhaps messing around in \HKLM\Hardware\Devicemap\Video might reveal something. My registry has a list of 6 devices, one is the VGAsave device and isn't normally. But two are have the same GUID and end in 0000 and 0001. I'm assuming those are the video ports. Then there's a MaxObjectNumber value set to 5, and ObjectNumberList binary value with 00 01 02 03 04 05 entries
I love that ideaBetter yet, why can't we just disable the ports via video card bios so they essentially become Tesla cards, negating the whole "number of usable ports" issue?
